NYC CNC Fusion 360 Tool Libraries & CAM Templates
Download Fusion 360 here: https://www.dpbolvw.net/click-9255839-12529306
For a more extensive feeds and speeds resource, we suggest ProvenCut. ProvenCut actively tests and publishes video-based feeds and speeds recipes across a range of CNC machines from hobby benchtop machines up to large vertical machining centers. Recipes can be searched by a range of criteria, including tool diameter, machine type, material type and more.
These Fusion 360 Libraries for Tormach & Haas Machines (both Aluminum and Steel) as well as our Templates are below.
Tool Libraries
Not Yet a Member?  Click here to download the NYC CNC Sample Tool Library
CAM Templates
Not Yet a Member?  Click here to join and get access to CAM Templates and more!  Templates include Mill, Lathe, 2 axis, 3 axis and 5 axis templates/samples for CNC mills and lathes, including Tormach and HAAS.
DISCLAIMER: Feeds, Speeds, Templates and all information on this page is intended to serve as a general guideline. Machine type, horsepower, spindle speed limitations, tool holding & work holding devices all may impact a cutting tool’s ability to perform properly.  NYC CNC is not responsible for tool failure, part damage or injury that may be caused as a result of the previous mentioned factors
If Files Incorrectly download as ZIP files
The file above should download as .tools or .F3d files.  Some web browsers, including Internet Explorer, will automatically change the filetype to a .zip file.  We recommend using Chrome or Firefox to avoid this, or you can manually rename the file extension after download.
How to Download & Install Tool Libraries
How to Download & Install Tool Templates
What Computer to Buy for CAD & CAM
Where to buy a Haimer 3D Sensor
